Is there a way to disable the router on the Mifi 5510L? I am using one with a Balance 20, and it gives the Peplink an IP of 192.168.1.X, making it impossible to connect from the Internet to the Peplink router. I was using a Pantech UML290, and it gave the Peplink the correct Internet static IP address so I could connect via VPN and monitor the router.
If it is the case that there is no way to disable routing on the device, are there any workarounds you could offer to allow remote access to the Balance 20?
No, the cellular connection is the only WAN connection. It would be helpful if it was noted in your USB modem support list which devices will allow a direct connection and which won’t. I had the same problem with the Pantech UML295.
