I have to insert a Balance 20 in an existing environment, the firewall is in bridge mode. The internet connection is goind trought a cisco router SMB and then pass to LAN (where the firewall is).
Can you please give me any advise on how i can insert the Balance 20 without modify the existing environment.
This is Tricky since the B20 doesn’t support drop in mode.
Do the firewalls (@ 3 and 4) get public IP addressing or is the CISCO doing NAT?
I would think that you’d need to replace the CISCO SMB @ 2 with the Balance 20 to make it fit
With a Balance 20 you could look to replace the CISCO or the firewall (assuming the firewall is not in transparent mode and is instead IP forwarding / NAT).
No other options that I can think of - assuming you want the Balance 20 to manage Dual WAN.
If you’re just using it for PepVPN routing then you could install it on the LAN.
