When upgrading hardware from one Peplink device to another, configuration files are not always compatible. Even older versions of the same product’s (eg. Balance 30 Hardware Version 3 in my case) configuration file may not be compatible with the latest version of the same product. This makes upgrading to new hardware cumbersome
Ideally, it would be nice to have a configuration file converter, or to have the software for new devices recognize configuration files from older devices. Assuming that is complicated to do correctly, a simpler approach is to streamline one of the more cumbersome parts of manually setting up a new device, which is porting the DHCP reservation table.
In the current interface, there is a way to export DHCP reservations as a CSV.
I would like to request a way to import DHCP reservations as well.
You can import the DHCP reservation list by copy & paste the exported CSV format data into the CSV format view. Just save the settings after pasted the CSV format data & apply changes. By doing this, you should able to get the DHCP reservation list into the device.
