I have Head and Spoke network. Spoke(terminal) sites appear starting in VPN connection when HQ(Balance 2500) site appears established. I checked the terminal site again but it is starting. What is this problem? HQ uses “Restricted” in PepVPN setting and terminals configure by default. Is it need to be the same setting? And I don’t understand Backward Compatibility in Peplink. Explain to me!!! How many have TLS versions and where firmware versions? How do they work? Thanks for all
Backward Compatible
High (default) - Ensure the hub and spoke devices are using v6.1.x and above. This supports TLS v1.0.
Restricted - Ensure the hub and spoke devices are using v6.2.x and above. This supports TLS v1.2.
Is it necessary to same on both sites? How is it work? Where do it need?
I will advise not to make any changes on this if you are not familiar. Unless TLS v1.2 is needed in your environment. If this is needed in your environment, please ensure all hub and spoke devices support v6.2.x and above. Then configure “Restricted” at all the devices.
Thanks for your support and advice.
