B1 5g with openvpn client - LIC-OPN-WAN
I have a B1 5g coming in tommorow.
I will be adding the LIC-OPN-WAN license so I can use my work’s vpn as a wan.
Can I add another openvpn wan connection so I can connect to NORD for the kids stuff?
I have no problems buying another license for this.
MY existing solution with a unifi uxg-pro supports vpn wans but the device gets unstable after a while and I want to switch from failover from fibre-starlink-lte to Fusionhub solo or maybe FC connect depending on my data needs.
Hi…
Do you want to use two ovpn wan in the same unit. I have buyed this license and this is not possible.
It is just allow one ovpn wan profile.
I have 2 OpenVPN sessions running at the same time, I do not have OpenVPN as WAN.
I have one profile used for security and one used for blocking ads that take up valuable data from our data plans they run at the same time, the ad blocker only switches over when necessary to block ads on our tvs, alexas, tablets, computers etc .
But… let me ask…
Did you do a double import of the files to have this or you just use one file with two profiles inside of it?
Some devices, already come with ovpn wan license by default and the ovpn wan license can only be added at my device when I did the purchase of it.
I have HD4_MFA. ( Pepwave MAX HD4 MediaFast)
I double import the Files, I have one going to the Netherlands, the other one going to another server. I use different ports and use compatible routing rules to make this work.
