I have a new Peplink B-One with mainly default settings that will not allow most traffic, especially websites, through its built in WiFi. However, sometimes it works and used to work fine but now mostly not.
The iPhone reports “The network is blocking encrypted DNS traffic.”
I don’t see any settings to block encrypted DNS traffic.
In fact, I did have “DNS over HTTPS” enabled and pointed it to NextDNS service. I disabled DNS over HTTPS to troubleshoot but still get the same error.
Starlink is the main WAN connection and the Starlink menu has it enabled. The wired connections are working fine.
I did find two other topics on this subject relating to DNS issues:
Both of these discuss issues with DNS over HTTPS. I went ahead and made some of the recommended adjustments such as setting the Time Server. But in the end, I turned off DoH and the iPhone was still not able to reach the internet.
I changed the WAN from Starlink to CenturyLink and the warning on the iPhone,that the network is blocking encrypted DNS traffic, persisted. So I do not believe this is an ISP issue.
I still have not found any settings in the B-One that relates to blocking encrypted DNS.
Do you think I need to factor reset this router and start over?
I have access to two other WiFi networks in my house. The first is a CenturyLink router (a service I hope to replace) and the WiFi router on the Starlink system. The iPhone does not have a problem with either of those WiFi networks. The iPhone does not give the error/warning. It persists with the Peplink router.
Therefore, I think the issue is with the Peplink B-One. I wonder why the router would be blocking the DNS communication.
Nothing new to report. I disabled the NextDNS on the DNS over HTTPS and things seem to be more reliable. It still happens every so often but I haven’t had the issues lately. I am not sure what changed.
