B-ONE-T-PRM and MAX BR1 Mini 5G
Good morning.
I’m new around here. Could you answer me a question:
1 - Does B-ONE-T-PRM need a monthly, monthly or annual license?
2 - Does MAX BR1 Mini 5G need a monthly or annual license?
Daniel
Both come with 1 year of primecare.
Then after 1 year the mini looses it’s wired wan, and both loose virtual wan, and the b one looses wifi-as-wan.
Good night. Thanks for the reply.
As I said, I’m not sure which peplink to get. Basically accurate for Live Streaming (Youtube and Zoom) and simple balance for up to 100 computers and mobiles. Any suggestions?
ISP1 - ethernet
ISP2 - Starlink
Daniel
The B One/B One 5G sound like they are more appropriate for you.
BR series are small ruggedised devices for industrial/IOT type applications. The Br1 Mini 5G is a small unit, the BR1 Pro 5G is the bigger/more powerful one. The BR1 Pro 5G and the B One 5G are directly comparable performance wise, but the B One 5G is cheaper as its not a ruggedised device.
See a comparison here: Peplink.com - Model Comparison
If you don’t need 5G backup, (you said you have ethernet & starlink) the plain B One is cheaper, if you think you might want cellular backup in future the B One 5G has that built in.
The b ONE has two wired ethernets.
Let us know if you want us to send you an estimate for it and help support it?
