B One control AP from remote Balance
We have many Peplink access points which we control from a 310X at the main office. Remote sites have Network > Local DNS records to have wlancontroller.com point to the 310X. It works great for all the AP devices.
Our remote sites primarily use Balance One routers. I learned long ago to turn off the internal AP on those because heat would build up and the device would shut down. That was a known issue on those older models.
I am installing a new B One. I assume the AP heat issue has been corrected? I want the main office 310X to control the internal AP of the B One. That does not seem to happen even though I have the DNS record.
Can the B One internal AP be controlled by a remote Balance router?
Hi, @Don_Ferrario
Yes… Internal AP is working without issues at new B-ONE. (I have the B-ONE WiFi only model)
No… It cannot be controlled by a remote bpl router.
