B One as an access point?
As far as I can tell, the least expensive Access Point with Fast Transition is the AP One AX Lite at about $300 right now in the USA. But for a few dollars more I can get a B One that has this feature (and whole lot more). My question is if the AP controller in one B One can “control” the AP in another one as if it’s just an Access Point. Any limitations to this setup?
Hi !
This could work with the latest Synergy WiFi abilities - meaning the WiFi on the Synergy slave would also work as an AP.
This would also add more WAN interfaces etc…
I have not tested this with a B One, so worthwhile testing before committing to it or seeing if someone in the community have.
That leads to the question if the AP-AX-Lite is to expensive or the B-One is to cheap. I guess a good price for the AP-AX-Lite would be around $180-200.
Well, I’ve only got one B One on hand at the moment and no other router to act as the Synergy primary. So it’s not me to test it.
