B one 5G in synergy mode -> Use Wifi as AccessPoint?
FeatureRequest: Would it be possible to use the Wifi-AccessPoint capabilities of the B-One 5G while used as a synergized deviced?
We use them for example with a B310-5G router to have three cellular connections at the same time, but the B310-5G is lacking any Wifi-Capabilities. So it would be super nice, while all the interfaces from the B-One are passed thru to the B310, that the WiFi from the B-One could also be used to function as a local AccessPoint.
Best regard,
Martin
That’s a good idea. Can you still remote into your b one 5g?
Are you able to turn on wifi or what does it look like?
I have an idea on how to interconnect them , but not sure if it’s possible or not.
hi, no can’t log into the b-one5g while it is in synergized mode. so we would need that feature to be implemented directly for synergize mode. i think it would be super cool to “passthru” such functions on wifi interfaces aswell to the device which works as the synergy-controller.
Hello @Machtl ,
I see where @Jonathan_Pitts is going and it would be a good work around right now, but would require some configuration on your part if you are comfortable with it.
From Incontrol you should still be able to remote into it, if you could confirm that (I can in my lab setup). But any config change there have to be done very carefully now.
This is definetly a grand idea!
Can you add me to your in control group and we can look at it together this afternoon?
[email protected]
hey, i am currently out traveling to a conference. will reach out again once i am back at office and the routers are ready. thx!
