B-210. E-Bay or garbage?
I have a Balance 210 that I tried awhile ago to make my main router. It was a big disappointment since day 1. Never matched it performance specs listed in the sales flyer. Software implementation, while nice by design, poorly implemented.
I opted for another brand that, while it requires more command line programming, it works.
So… is it worth trying to resell or do I throw it in the recycle bin at the dump?
Wow, what a loaded question. Sorry things didn’t work out for you. Which hardware version is it?
There is a very healthy 2nd hard market for Peplink devices. If you remove it from incontrol and market it as removed more people will consider buying it. Otherwise it will be harder to sell.
For slower networks or as a training device a B210 has value. I’d try and sell it if I was you.
Best of luck!
It’s rev 4… the in-control was locked when I bought it second hand. And, of course, tech support doesn’t help you unlock anymore…
