Hello, I’ve looked over posts similar to my situation but was unable to find an answer.
We currently have 2 Cisco ASA’s deployed in Active/Standby High Availability configuration with 2 internet links.
We have purchased a Peplink Balance 380 and hope to use it to balance the WAN links. I plan to use “Drop-in” mode for WAN 1 but would rather not assign a public IP to WAN2 and avoid using NAT. If this is done, a double NAT scenario would be created as the firewalls are performing NAT as well. Both links are hosting externally available services and double NAT means double the configuration changes. Is there another way to configure the 2nd WAN link?
Thank you,
Ben
