Automictically Disable SpeedFuison Cloud or send emails alert when Quota Ends.
Hi All
We had a bunch of LAN clients’ data traffics just stop when the Speed Fusion data Quota limit reached. The clients’ data traffic flow again when the SpeedFusion Cloud is manually disabled.
(preferred ) Is there an option to automatic to disable SpeedFusion Cloud when the quota is reached so the LAN clients will not get blocked?
Or way receiving an email before SFC expires or data quata usage threshold has reached?
Sonny
You can setup priority rules under outbound polices instead of the easy rules under speedfusion cloud section.
Set SFC as top priority, followed by the wans you want to use.
