Will the surf on the go support connectivity from an at&t mifi in usb mode?
I would like to verify that this connection will work or not:
Internet -> AT&T mifi LTE velocity -> USB -> Pepwave Surf -> RJ45 -> Apple Airport -> Devices
The physical connection is fine. Anyway, AT&T Velocity is not listed in our supported 3G/4G LTE USB Modem. I suggest open ticket if you have problem to connect it. We will look into the possibility for driver development.
