Where can I associate network interfaces with LAN or WAN? When I log in via console I only see WAN configuration an no mention of my LAN interface. I do see a tab for both WAN and LAN in the web interface but how and where are they associated with a specific interface? I added on a NIC after I first configured FusionHub but I can’t verify if it is connected and I think it must not be as I don’t seem to have LAN connectivity (from VPN side nor can I ping or access FusionHub web interface via LAN). I first did static config and nothing worked so i enabled DHCP as a test and it doesn’t seem to be picking up an address… makes me think this confirms it isn’t connected.
On the other hand, when doing a license check (which is why I added LAN interface to start with) it seemed like it did use the LAN. I am using VMware.
I am about to recreate the whole thing starting with a 2 NIC configuration to see if it works on setup but was hoping there was another way so want to check with you all.
