Have anyone been able to assign a Static IP for FusionHub Virtual Appliance in Azure? So that static IP can be used as a WAN interface for speed-fusion connections.
Are you referring to Azure cloud IP reservation ? If yes, you can refer to the URL below:
https://azure.microsoft.com/en-us/documentation/articles/virtual-networks-reserved-public-ip/
Thank You
Yes Exactly! Will reserving a static IP for the virtual Machine where the FusionHub is install will allow me to create a pepVPN and speed-fusion connections. I would try it by myself to confirm it but my trial fusionhub was ended while testing in AWS.
