Hi all
we want to install pepwave MAX700 and pepwave HD2
There are several points we need to know:
A. Because our application is a single video conference session requires a minimumnamum 512 kbps link, then the first session should be divided into multiple operatortraffiknya (3G dongle). How can Peplink solution to address the issue of reconstructionof the packet / stream from the user and the data center that will occur because of differences in delay of the multiple 3G operator?
From the discussion earlier, it takes a static IP assignment for each of the existingGSM card so it can be made into a tunnel. Are not there other mechanisms toworkaround this situation? For example, using a dynamic VPN tunnel? Is this amandatory requirement?
Is load balancing between multiple uplink algorithm can be in the mix? For example,persistence mode for HTTPS applications while other applications use the weighted round robin.
Thx
Tri
