Are you able to add multiple inbound port forwarding rules on a balance 20?
We have a balance 20 (upgraded to have the 3 wans with an activation key). I am looking to add multiple inbound port forwarding rules at once via the command line like a batch file or by uploading a config file that I can edit. We are looking at adding 100 inbound port forwarding rules for some software that requires these rules to access the different devices on the network. Is it possible to have so many rules? And is there an efficient way of doing it? Doesn’t necessarily need to be via CLI or batch files.
The device is running version firmware 7.1.0 build 3504 and it is hardware revision 6.
Thanks in advance
Dave
You can upload a config file to edit and using port ranges may help with this.
