Are there any 4g/5g peplink solutions that can use 4 sims?
Hello.
Do you check about HD4 MBX?
" Peplink eSIM "
I have searched quite a few of those distributors but can’t find pricing anywhere. Is there anything around there that is more available? Does Peplink have devices that can join via ethernet but only have 2 sims?
@Shawn Do you want 4 simitanious connections or the ability to use more then 4 sims and move between plans and/or regions? What is your use case? We are a peplink partner and can help you plan out what you need.
4 simultaneous connections
Hi Shawn,
If your project has some budgetary constraint, you should consider pairing 2 UBR Plus, this should be much more affordable.
Shawn,
Do you want the 4 connections in one unit, or do you have space for two to four individual routers and one main router.
Ideally, I’d want to carry the equipment on my person. That dream is most likely dead. I plan on carrying them around mounted in the trunk of my sedan, so I have space for multiple units.
Is it that I can have multiple single cellular modems and still have the bonding abilities via some other peplink device?
If you want to carry on your person, max portability I would do one or two transit pro duos.
I have a couple of options here on this comparision link.
Let me know if you are interested in ordering any we are a peplink partner and can help you make a decision and support you after the sale.
Peter West makes a neat case with three 5G modems in it (BR2 pro and a 5G adapter). You could do WIFI WAN from that to your 5G smartphone for the fourth…
The HD4 MBX retails for $10K. I have access to one at $4k, NIB I’d sell or give you the info on so you could buy.
BR1 PRO 5GN is a single radio, dual sim + Wi-Fi and 3 ports of Gig-E Ethernet WAN or LAN. You can get the BR2 if you need to use two SIMs or E-SIMS at the same time.
One thing that I notice about these 5g modems is that they have a reasonably high speed. I’ve been researching more about 5g cat speeds, in general, to ensure that I’m even asking the right questions, and I landed on a question I couldn’t answer.
If I have a CAT18 5g modem, will my local carrier allow me to transfer at those speeds, data caps aside? If so, I might only need two modems, and my problems will not be so severe.
What is a “peplink eSim” ?
So there is no peplink that can use regular eSim?
As far as I know every new model supports 2 physical sim slots, 1 esim (speed fusion profile, 2 additional esim profiles) and then some models support remotesim.
We are a peplink partner and can help you with sales and selection, let us know what your budget and needs are.
