API login failed due to SSL certificate invalid UBR-LTE
Hi everyone!
Recently, I have been seeing some issues with my routers when I try to log in using the API. Error says:
[ERROR][ROUTER][REQUEST]: Data of UBR-LTE router not retrieved because <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: IP address mismatch, certificate is not valid for '192.168.50.1'. (_ssl.c:1007)> URL: http://192.168.50.1/api/login
Initially, one way we had to solve it was to update the firmware to 8.3.0, but this seems not working anymore. Also, it is not happening on all the routers, only on some. Why is that?
Thanks in advance!
Following up with this request, we just purchased a new MAX-BR1-MINI 5G, and this is happening once again, while it has the latest firmware update 8.5.2
We still don’t have support on this, please help.
I would suggest you log a ticket with engineering for review.
