I would like to know how to pull the GPS location and map into my own application from either the device itself or from incontrol.
Matt Humbert
Matt Humbert
Matt,
You can see GPS related information here:
Here is the API information if you want to pull data directly from IC2 into your own application:
https://www.peplink.com/ic2-api-doc/
