I’m trying to figure out which GET command to retrieve the WAN / Cellular signal strength. I’ve tried a few different ones listed in the api doc for 8.5 but none of the listed commands retrieve that info.
Any additional help is appreciated.
Hi…
Maybe this help you.
okay, but theres no way to do it with the device directly, it has to be done through incontrol?
Hi…
Looking here… I don’t find a solution… You are not the first that request this, directly to the device.
Peplink only provide solution, using IC2.
Maybe this will change with the next release of 8.5.x version?
okay, good to know.
i’m having zero luck with the incontrol API, not sure why but nothing is working. I’m also a bit new to this so its a bit challenging.
I will try, something simple, at monday… send here the result.
updating…
@Dustin_Betterly
Have you try this?
Updating…
Using IC2 api
Create a ID and password at IC2
I download the sample script here. https://download.peplink.com/files/ic2/sample_ic2_api_client.sh
Edit the script and change the values of
client_id=" "
client_secret=" "
execute the script and works.
It is a simple sample, got from Peplink.
Result script at screen…
Listing all accessible organizations’ group names.
Groups under the organization: AT4
AT4
Groups under the organization: Anatel - testes
Anatel
okay?
Thank you for this. I was able to make some progress over the weekend, but I’m still struggling with getting my refresh tokens to work. The short term token is a real problem (at least for me…) for hard coded programming. I’m working on the refresh token, but it’s giving me problems. I’m quite new to this stuff, so I’m trying to work through it.
@MarceloBarros have you had any luck with coding a refresh token? After a lot of tedious work I’ve been able to pull almost all the info I need using the API, but the token validity period is creating issues for me.
Hi, @Dustin_Betterly
I will check…
Hi… Just test it… no expiration… the token ID and password… are still valid.
kiko@raspberrypi:~ $ ./sample_ic2_api_client.sh
AT4
Also… check at my profile at IC2 and no expiration date on it for the api token.
Hi… another update…
At this link…
https://www.reddit.com/r/Peplink/comments/1iwbqwc/peplink_ic2_api_refresh_token/
He is having the same issue at you.
