Does the AP PRO 300M support using both frequencies of antennas simultaneously? It looks like it does not come with antennas and that it supports 2. Does not state if you can use 2.4 and 5 GHz on a single AP. Can anyone offer some intel on the topic?
Hi Tom, the AP Pro 300M has a software selectable 2.4 or 5 GHz but not both simultaneously. No antennas are included and the connectors on the device are N-Female. Thanks
