Probably a dumb question but I haven’t found the answer. What makes some SSID to appear greyed in AP One ?
Well, after some fiddling it look like it is a bug. Now, this is what I get:
Timing of events in IC2:
- created new SSID using WPA2/WPA3 personal in IC2
- changed WPA2/WPA3 to WPA2
did tests for a while with one WPA2 only aware laptop, ok
- assigned a captive portal to the SSID in order to check if it has some effect on greyed display. no change
- removed captive portal
laptop traffic is not routed anymore, even after wifi association close / re-open.
- power cycle of the AP
Apparently fixed with 3.7.3 build 1050
