AP One Mini as Wi-Fi Bridge
Good day. I see the datasheet for the AP-ONE-AC-Mini states bridge mode is supported, yet, I cannot seem to find any documentation supporting how to use it as a layer two bridge to a wired device.
Use case is to provide LAN access to a wired client using Wi-Fi as it’s uplink.
Bridge mode is referred to in the manual as bridging or joining wireless clients to an ethernet cable.
I believe what you are wanting is using the AP as a wireless client to an existing wireless network and connecting a wired device that way.It’s not supported in that manner.
If you have a peplink router that supports mesh you can setup both of the pepwave router and the ap as mesh devices. It would then allow uplinking a wired device over wifi.
To do a wifi client in the way you are thinking you would need to use their Device connector series(no longer supported) or a soho/20x/b one and enable the wifi-as-wan wan to uplink wired clients.
You can find this information here:
AP One / AP Pro
Depending on which hardware revision you are using it is linked below.
AP One AC Mini HW2 3.9.3 Online Manual
AP One AC Mini HW1 3.6.3 PDF Manual
