Can someone tell me why the SSID settings have a DHCP server option? Because I can’t get it to work.
Here are my Settings:
SSID Settings
Enable
Radio Selection 2.4GHz5GHz
Band Steering
Disable
SSID
SSID_TEST_DHCP_SERVER
Broadcast SSID
Data Rate AutoFixed
MCS16/MCS8/MCS0/6M
MCS Index
Multicast Filter
Multicast Rate
MCS16/MCS8/MCS0/6M
MCS Index
IGMP Snooping (Multicast Enhancement)
DHCP Setting
Server
IP Start Range
192.168.90.20
IP Stop Range
192.168.90.200
Subnet Mask
255.255.255.0 (/24)
Broadcast Address
192.168.90.255
Gateway
192.168.90.1
DNS 1
8.8.8.8
DNS 2
4.2.2.2
(optional)
DNS 3
(optional)
Domain
(optional)
Lease Time
1
Days
0
Hours
0
Mins
DHCP Option 82
Default VLAN ID
20
VLAN Pooling
VLAN Pool
(CSV: e.g. 1,3,9-11,15)
Network Priority (QoS)
Gold
Layer 2 Isolation
Maximum Number of Clients
0
(0: Unlimited)
Security Settings
Security Policy
Open (No Encryption)
Captive Portal
Captive Portal
Disable
Access Control
Restricted Mode
None
MAC Address List
Connected clients:
D0:C6:37:57:F0:17*
- suffix = client connected to SSID_TEST_DHCP_SERVER
RADIUS Server Settings Primary Server Secondary Server
Host
Secret
Authentication Port
1812
1812
Accounting Port
1813
1813
Maximum Retransmission
3
Radius Request Interval
3
s (initial value, double upon every retransmission)
Guest Protect
Block LAN Access
Custom Subnet
Network Subnet Mask
255.255.255.0 (/24)
Block Exception
Network Subnet Mask
255.255.255.0 (/24)
Block PepVPN
Bandwidth Management
Upstream Limit
0
kbps (0: Unlimited)
Downstream Limit
0
kbps (0: Unlimited)
Client Upstream Limit
0
kbps (0: Unlimited)
Client Downstream Limit
0
kbps (0: Unlimited)
Firewall Settings
Firewall Mode
Disable
Schedule
Scheduled SSID Availability
Always OnCustom Schedule
ARP Request Control
Default Handling
BypassDrop
Custom Action
IP
MAC Address
ACTION
