Is it possible to connect any of the AP One products to a Wifi network and use the Wan port ale LAN extension?
Regards
Robert
Regards
Robert
I believe the product you are looking for is the Pepwave Device Connector:
Does it mean the AP One Flex 300m can’t do it? Even with license or other?
If connected to an HD4 as a slave, can it then be used by the HD4 as external AP for his WiFi as WAN?
The AP One Flex 300M is an access point only and cannot be used as a Wi-Fi as WAN, you would need to use the Device Connector instead.
