Dear Haruki ,
I need to urgently know if it’s possible to backup/restore AP One series to each other ?
We need to restore an AP One 300M backup to AP One mini.
Thanks and regards,
Hootan
Dear Haruki ,
Thanks and regards,
Hootan
Hi Hootan,
Yes, it’s possible to backup/restore AP One series each other using the same config.bin file.
Please be informed of the followings.
I hope this clarifies the matters.
Thanks Haruki ,
I wonder what functions are just related to AP One 300M ?
Thanks - Hootan
Well, for instance, AP One 300M is compatible with both 2412 - 2472 MHz and 5180 - 5825 MHz (these frequencies don’t operate simultaneously) while AP One is 2412 - 2472 MHz only. So if you set up 5Ghz in AP 300M, download the config.bin from it and upload it to AP One, then you only get to use 2.4Ghz in the AP One because AP One is only compatible with 2.4Ghz. This is a simple example. I hope this gives you an image of how it works.
Dear Haruki ,
Completely understood.
Thanks and Best Regards,
Hootan
