AP One AX Lite
I updated my BR1 Pro 5G to firmware 8.5.3. I don’t know if this caused it but my AP One AX Lite is no longer functioning. It is powered by a Gigabit PoE Injector. I unplugged the AP One and plugged it back in. It reboots, first light goes from red to blue, then all lights go blue, then all lights go off and stay off. I’ve tried rebooting numerous times and it always turns itself off. Any suggestions to get the AP One AX Lite functioning again?
i dont know that the AP failure would be connected to a firmware update on a separate device. have you tried powering on the AP with a different power supply?
I had the same thought. I don’t have alternate power supply but am working on getting one.
