Balance one with internal AP turned off. one AP one AX. One AP one AX lite.two SSIDs. On the AP one AX i can connect to both. On the ax lite i can only connect to 1 SSID. The bad SSID doesn’t assign an IP address to my phone (no internet (its assigning default IP addresses outside the scope of my network)). both aps are managed by the Balance one. all have the latest firmware. Does anyone have any troubleshooting tips?
So it appears that he ap one AX lite is not using DHCP on the 2nd SSID. whereas the AP one AX is.
Solution : I had to tag a port on the poe switch to pass the vlan traffic from the new SSID assigned to a VLAN
