I just recently added an AP One AX to my BR1-Pro 5G on my boat so that I can use my 42g antenna solely for wifi as WAN. I am using InControl2 to manage the devices, including the Wi-Fi settings, and the AP One AX is in standard bridge mode. My question is regarding the LAN IP address on the AP One AX. The AP One AX came from the factory configured with a LAN IP configuration of 192.168.0.3/24. My BR1-Pro 5G has a LAN configuration of 192.168.50.1/24. Is this fine as is? Should it be changed? why? why not? I’m moderately intelligent with network configuration but this has me scratching my head a bit. TIA for the inputs!
Hi David,
by defaul AP One AX or AP One AX Lite are configured as DHCP client. So on power up it should be able to get IP address from BR1 Pro 5G.
In case AP can not get the IP address, then it falls back to 192.168.0.3 so that you cold access it.
