I’ve downloaded and updated my AP One AX to 3.9.4b5000 but then it automatically “updates” back to 3.9.3b4976. Any suggestions?
You may have a firmware policy for 3.9.3 set via InControl.
I do not have InControl enabled and the AP is not even listed when I do view InControl.
Sorry if I’m being pedantic, but I recommend you add it to your IC2 environment to prevent being claimed by others. If someone else has claimed it in their IC2 and set a firmware policy, that could be causing this.
How is that possible if I have InControl disabled on my MAX BR1 Poro 5G and my AP One AX is managed by my router.
I don’t have Controller Management in the System tab. But I did find how to set the AP firmware from the AP tab of my router. Thanks for the help!
