When I try to connect with my PC via wireless internet, I get the message ‘Enter The Network Security Key’. How do I find that? What is it?
I assume you’re trying to connect wirelessly to your Pepwave AP One AC Mini.
The network security key should be the WiFi network password.
The default WiFi password of a Peplink/Pepwave device is the last 8 digits of the LAN MAC.
In example: If your LAN MAC is ‘00-0A-AA-00-00-00’, your WiFi password is ‘AA000000’.
I hope this helps!
