In the Advanced Wireless Radio settings for the AP One 300M the Tx Output Power options are MAX, High, Medium, and Low. What actual dBm (or mW) values do those options correlate to? My deployment environment requires that the AP output power be set to 1-2 mW. Is this AP capable of that? Thanks in advance!
AP One 300M Tx Output Power as below:-
2.4GHz
Max - 25dBm
High - 22dBm
Medium - 19dBm
Low - 16dBm
2.4GHz (CE)
Max - 17dBm
High - 14dBm
Medium - 11dBm
Low - 8dBm
5GHz
Max - 22dBm
High - 19dBm
Medium - 16dBm
Low - 13dBm
5GHz (CE)
Max - 17dBm
High - 14dBm
Medium - 11dBm
Low - 8dBm
Thank you! Thanks exactly what I needed to know.
Hi Team,
Please I need the same information (Max Tx Power) for the AP One Enterprise and AP One Mini.
thanks in advance!
@hentati, you may find the requested info below.
