Hi there,
I have been testing the AP Controller on both a Balance 20 and Balance 305 both with the 8.1.2 Firmware. My understanding from the Peplink webpage is that the 20 should have “AP Controller Standard” and 305 should have the “AP Controller Pro”. Interestingly, I was able to create multiple configuration profiles on both the 20 and the 305 even though documentation says this should only work on the “AP Controller Pro” models. Does anyone know, has this restriction been removed and now all AP Controllers can do multiple profiles? I am looking at purchasing a Balance One and need to to be able to support multiple profiles but the documentation says it won’t… even though for some reason the Balance 20 seems to.
Thanks!
