any way to track roaming data use?
Hi there,
I’m wondering if there is a way to track how much data is used when roaming. This is for plans where there is a limited roaming allowance, in this case international roaming. I am on the border where often the best or only cell tower is in a different country so guessing based on time ranges isn’t very effective without a lot of work correlating the data from the wan quality report and mapping it to hourly data use.
I’m not picky about where, incontrol, on device, or breaking it down by the carrier shown, which differs when roaming. I’m hoping there is some hidden option I haven’t seen.
I’m using a max transit duo.
Not at the moment, as far as I can tell anyway.
I made a post a few days ago asking for the same thing :slight_smile:
https://forum.peplink.com/t/Ic2-SIM-Pool-Roaming-Data-Allowance/624ab681a02a7ad64ddb0a3f/
