Hi everyone, if I want to do WAN Smoothing and send VoIP/SIP traffic only via SpeedFusion, is there any easy way to just isolate all of that? If I view active sessions it will show “SIP” traffic so it knows what SIP is, but in outbound policy there’s no way I can see to just pick SIP. Instead I’ve been saying traffic going to the SBC IP addresses needs to go over SpeedFusion, or sometimes UDP port 5060 and then whatever other ports. Just curious if there’s an all in one way to do it without having to ask the customer for the IP addresses of the VoIP providers’s SBC. Thanks!
If you can ask the customer for the SBC IP then its a single rule (all traffic for that destination IP over WAN smoothing). Otherwise you can do it by destination port typically (so 5060) and you can monitor the traffic and work out the RTP port ranges also (or ask them for which RTp ports are configured to be sure) but that is multiple rules. I would do it by destination IP(s).
Great thanks that’s how I do it now which is fine but just wanted to make sure I wasn’t reinventing the wheel in case there was a one click way to do it. ![]()
