Antenna MAX Duo - Installation Guide
Hi Everyone,
We would like to ask community feedback on the Antenna MAX Duo Installation Guide:
We are planning to prepare installation guides for other antennas and potentially for routers as well. Your input will help us to define the best format and improve the clarity and usefulness of these documents.
Any comments, suggestions, or improvement ideas are greatly appreciated.
Giedrius
Great stuff Giedrius!
Any data on wind speeds?
And in particular the adhesive mounting option :slight_smile:
Thanks!
Hi Joey,
We have tested the Antenna MAX and Antenna MAX S at wind speeds up to 60 m/s Testing was done for 10min on different angles and then visually reviewed if there a no deformations.
The Antenna MAX Duo is designed to withstand a similar wind load. All tests were performed using the L-Mount. We cannot provide an estimation for the adhesive-mount option.
G.
