Antenna MAX Duo
High-Gain. Zero Loss. Dual Power.
You’ve seen the power of zero cable loss from our Antenna MAX series — unlocking stronger 5G performance.
Now, meet the newest addition: Antenna MAX Duo.
It keeps everything you love — zero cable loss, easy installation, and IP67-rated outdoor design — while adding something more: greater flexibility.
With the cellular antenna array now increased to eight high-gain elements, the MAX Duo lets you power a dual-modem 5G router like the BR2 Pro, or even two single 5G routers, all within one enclosure.
Learn more
Very interested!
How do I translate this improved signal gain into real world performance/range?
FAQ SAYS ->> Maximum signal gain up to 8.1 dBi for 5G/LTE and 7.4 dBi for Wi-Fi by removing RF cabling
I currently have roof mounted antennas and those rely on 15ft cables. (Panorama White MAKO Dome Antenna (4xCell,2xWiFi,1xGPS) (LG-IN2445-W)
What would be the improvement over what I have?
@Emily_Cheng are there any plans in the product development pipeline to add a mount for a Starlink Mini to this Max Duo, in the same way that Max S did for Max? --Mike
Hi Can I fit a MAX Transit Duo Pro, MAX BR1 Pro 5G and a splitter, inside the Antenna MX Duo? The data sheet does not show the dimensions of the internal space. Thanks.
Hi Matthew,
MAX Transit Duo Pro, MAX BR1 Pro 5G and Splitter MAX should fit. However, there are no fixation points for MAX Transit Duo Pro so you will need to find a solution how to solve it.
Giedrius
I received the (very big!) box today.
Lots of bits and pieces. No instructions. Nor could I see any instructions on the Peplink site.
Where would the instructions be?
Cheers,
Z
you can find installation details and instructions on Antenna MAX Duo datasheet. Here is link to it.
G.
Suggestion: Peplink may want to place a slip of paper in the package letting owners know where to find the manual – perhaps a QR code. Expecting the owner to know to download a spec sheet to find install instructions is unintuitive.
Hi Rick,
thanks for the suggestion. We will implement it
G.
Fair enough - I did not think of the data sheet as also being an installation guide.
Cheers,
Sigurd
Anyone able to measure the internal space dimensions of the max duo? I cannot find any specs or diagrams that show the interior space.
