Is Peplink planning on making a 8x cellular, 2x wifi, 1x GPS antenna to go with the max BR2 pro 5g?
Not as far as I am aware at the moment.
If space is not a premium you could use 2x Mobility 40G antennas and disregard one of the GNSS elements, or 1x 42G + 1x 40G if you wanted to get the WiFi in there too.
Taoglas makes an 8x cell + 1x GPS antenna but no built in WiFI elements which we have been using with good success, they do have options with built in WiFi too but normally at the expense of some cellular elements or you’d need to mux the WiFI elements yourself as they are presented as separate cables for 2.4GHz/5GHz.
we have been working on new Mobility series antenna to support 8x cellular, 2x wifi, 1x GPS antenna. So far by specs this is the best antenna we have designed. No preliminary release date is set yet, but as always the goal is to get it ready in a shortest possible time frame.
Thanks for the update, great news. Look forward to seeing it!
