The link below seems to be dead:
https://forum.peplink.com/t/antenna-selection-guide-for-peplink-partners/13969
“antenna selection guide for peplink partners”
It was mentioned in a previous post and I would like to have a look at it.
Anybody knows how I could get it?
Hello @fdmarine,
As noted in those posts with the link,
Happy to Help,
Marcus ![]()
Hi Marcus,
I am confused.
I am signed up as a partner but I don’t see anything on my Partner Pavilion.
Regards
Frederic
Hello @fdmarine,
Contact your Peplink account manager and ask them to have you added into the partner section of the forum, they’ll be able to ask the forum administrators to adjust your access for you.
Happy to Help,
Marcus ![]()
Thank you Marcus, I will.
Frederic
Hi Marcus.
What is the current LTE-A world coverage ?
Should I buy a LTE-A ready router for the Caribbean/Bahamas area?
Also, I have been recommended the Poynting omni 402 over the Ant-100 LTe4-g for a marine application using a MAX HD2 Router. What’s your take on this?
Thank you
Frederic
Capt. Frederic Daillant
Marine Professional
Cell. +590 690 224517
Cell.2 +1 721 523 0691
Hello Frederic, @fdmarine
The only source I can reference you to is Wikipedia
Each country has slightly different variation as does each carrier. In Australia, the three major carrier each have varying coverage of LTE (Cat4) and LTEA (Cat6, Cat12 & Cat18). The best option is to speak with the carriers you wish to use, many have coverage maps on their websites.
Happy to Help,
Marcus ![]()
Thank you Marcus.
