ANT-MB-42G-S-B-6 CAD File
I’m trying to do some mechanical modeling for our system which will use a Pepwave HD4 and a 42G antenna (ANT-MB-42G-S-B-6). Is it possible to share a mechanical model that we can use for planning for the cables etc.?
thanks,
Hi there, thanks for reaching out to us!
Here are the STP files of the two models you requested:
I hope this helps!
Regards,
Cecilia
