A new evaluation license is required for each Instance launched on Amazon using the FusionHub AMI. My use is for live streaming and will only need the Amazon Instance running when we have an event. The type of Instance will also vary depending on event needs.
There needs to be a way to use the same license on different Instances. A check can be done to ensure the same license is not in use on multiple machines at the same time but it should not be tied to one machine.
I would need a solution to this before I purchase FusionHub
