I’d like to put in a request for the SDX (non-pro) model of Balance router to be allowed to use its integrated 8 LAN ports as WAN connections. To me, the SDX is just an SDX Pro with a built in 8-interface expansion module. If we buy an 8-port EXM expansion module, we are able to use those ports as WAN ports. I see no reason why these built-in interfaces would not be allowed to be used as WAN ports. Please consider making this change.
Hi Maxwell,
We deployed a few SDX originally not knowing these ports could NOT be used as WAN interfaces (until we got VLAN WAN).
It meant we had to improvise until VLAN WAN became available - and it still limited to only 3 VLAN WAN interfaces.
I would be very happy to see the LAN Port able to be converted to WAN Ports.
Support this request +1
Thanks Nik - I am in a similar boat. I also bought this device assuming that they could be used as WAN, since you could do it with an EXM module.
Hey @Captain_Nik - how did you get VLAN WAN working on your SDX units?
Hey Maxwell,
For the SDX (non-Pro) we ended up installing a FlexModule on one unit, and adding VLAN WAN licenses on the other.
Essentially using a switch as our WAN input with VLANs going to the SDX SFP+ Port.
I think the SDX (non-Pro) won’t ever get these features as it would undermine the Pro version.
However, in general it would be amazing if all ports could be either LAN or WAN - but again, this would undermine certain models against big brother products.
Thanks Nik.
Also @ The Peplink Team - just humbly requesting this again on the 1-year anniversary of this post
