Can we add an alert on cellular stuck on Connecting…
If it’s more then 10 mins or something, then it’s likely an issue someone needs to look at.
Probably easiest to add on ic2.
Sometimes clients will move other wifi accesspoints close to the BR1 mini causing the cellular to not connect. Then we don’t know this is an issue until we need to use it.
No this alert should be different, and specific based on it connecting for 5 mins and not progressing further. The cellular goes up and down sometime based on the tower , but what we are trying to alert on is when it’s stuck in connecting. We also have a schedule to turn off the cellular at a specific time and don’t want alerts for that as well.
