Hi ,
what is the required configuration steps to aggregate 2 sim cards and 1 wan connected in Peplink UBR Plus
Hi ,
Hi.
Hi Martin ,
I just need to aggregate them internally but unfortunately i cant . I am not getting the sum speed for all of them . I am getting the speed of just one of them
Hi, @nh.ibs.noc
Please… check about your device at
Do you have primecare up to date?
Type the serial number of your device at
https://estore.pepwave.com/
Choose search… You will see informations about your device.
Without primecare… your device only do the balance of the wan (include sim cards) of the links.
maybe SFC (peplink SpeedFusion Cloud) service, will be a solution for you.
You can read about at
And choose the best plan for what you need.
