Advise on a external antenna for my Balance 20X
Hi all,
I am after some advise on what would be the best external antenna for my 20X, It will be used a Home environment with 1 x 900 mbps FTTP connection (main connection), and a 4G unlimited data sim as backup connection, I would like to use an external antenna so I get better 4G signal and thus better data rate.
I had a look through Antenna section on peplink website but I could not find an antenna that was 2 x Cellular only, Any suggestions ?
Andy.
would this https://download.peplink.com/resources/pepwave-ant-102.pdf be ok ?
or am I better off just getting Puma 401 ?
Andy.
Hello @AndrewStyblac4791
You can use the Pepwave Puma range though we suggest that you contact your local Authorised Peplink Partner for specialised assistance.
Your local Certified Peplink Partner can help you with a copy of the Antenna Selection Guide for Peplink Partners , this is a detailed guide and is only available to the Peplink Partners so to ensure that you get helped in working through it to get the most suitable antenna solution to your application.
Happy to Help,
Marcus :slight_smile:
