Hi everyone
kindly i need your advice to put a very well rules to my load balance peplink 710 , i have 2 WAN’s connection (ISP’s):
WAN_1= 20 MB
WAN_2= (40 MB external traffic + 40 MB google traffic ) as a total 80 MB.
currently, i have put 2 rules :
i forced google traffic to my second wan as shown below
second rule that is default which i used weighted algorithm
by using these 2 rules the bandwidth of WAN1 is saturated while on WAN2 no exceed 35 MB as shown in MRTG.
1. Can you please confirm whether IP range 212.126.124.1/24 belong to Google ? Base on the Whois IP lookup, the IP address is belongs to AL-SARD FIBER. If the defined IP address is invalid range, this will cause the defined outbound policy doesn’t match to the Google Traffics.
inetnum: 212.126.96.0 - 212.126.127.255
netname: IQ-AL-SARD-20100525
descr: AL-SARD FIBER Co. for Internet Fiber and Optical Cable Services /Ltd.
country: iq
org: ORG-ACfT1-RIPE
admin-c: IA3282-RIPE
tech-c: KK4687-RIPE
status: ALLOCATED PA
Step to obtain Google IP address ranges:
Beside that, we will advice to change the Google Traffics using outbound policy algorithm “Priority”. This will allow Google Traffics fail-over to other WAN.
2. You should have HTTPS persistent rule for the outbound policy. This will make sure some HTTPS connections that require to maintain connection persistency.
Overall, you should have the following outbound policy:
3. After defined the proper Google Traffics/HTTPS Outbound policy, if you still find WAN1 is saturated for long periods of times, do consider to lower the WAN1 “Load Distribution Weight”.
i really appreciate your kind support
for Point 1 , yes our ISP (AL-SARD FIBER) provide us their google traffic IP address.
for Point 2 i did the required let’s monitor it.
Can you please move the HTTPS Persistent outbound policy below the Google Traffics ? This to make sure “Google Traffics” doesn’t overwrite by the HTTPS Persistent policy. Please follow the sequence as given.
