We have 2 units of BR1, do we get free Fusion Hub license for these two units? Or need to buy it separately?.
Hi Aigie,
You can get FusionHub solo for free for 1 device, if you require both BR1 units to be under the same Fusion Hub then you need to get a license. Here is the info for Fusion Hub solo : https://www.peplink.com/products/fusionhub-solo/
Hope this helps.
