Im trying to advertise routes (public IPs) over OSPF to a BGP gateway where our traffic will go onto the internet.
We have an OSPF relationship with the 580x on the remote site.
But on the FusionHub side (running in VM) I dont see an advanced tab, there is no routing setup on the Fusion Hub end of the ink.
Is there a way to get this to show?
hi…
Are you running the last version… 8.5.1? correct?
FusionHub is a SpeedFusion concentrator and nothing more.
8.0.1 build 1644
So there is no way to have a routing session with the Speed Fusion Hub? Is there something missing ? It reaches the internet like this, and its passes static routes, but it needs to be dynamic.
You should really update to 8.5.1 and then these options will be available. You’re a few years behind in software versions.
Thanks guys, we just killed the VM and installed 8.5.1
The routing options are all there under advanced.
I turns out it might be easier to use BGP in this instance than OSPF, we are experimenting.
Thanks for the input
Just a note that you can upgrade the image in a VM, it’s the same as updating a device, so you don’t need to blow away a VM unless you really want to
